Hello,
Early in the summer I replaced my underpowered lead-acid battery with a 100Ah LiPO4. It was a straight replacement and I re-used the group 24 battery box in the tub of my 2022 T@B 320S.
I'm now contemplating adding a 2nd 100Ah Lithium battery and for now I would prefer to add it in the tub also (that may change later)
I haven't found a dual battery box that would place the batteries in this orientation (II) rather than (--) if that makes any sense (
https://www.amazon.ca/Camco-55374-Hardware-Safely-Automotive-Anti-Corrosion/dp/B07QJ2MBRD)Is my only option to build my own or do they exist and I just haven't found them?
Also contemplating in replacing the 20lbs propane tank with a 10lbs propane tank to gain a bit of room back and reduce tongue weight if needed.
I would appreciate any input or thoughts you guys would have. Thanks in advance
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Way, way less $$ then another lithium battery
Given that when pairing batteries, they need to be the same age, I would confirm with the manufacturer that adding a second one months after the first won’t cause any issues.
https://www.camco.net/camco-vented-rv-marine-battery-box-double-side-by-side-55370
I need more watts than I need propane based on this year's experience.
I bought this box for my AGM batteries.
Here's a thread where someone else used the same battery box I bought.
North Georgia
@Marceline yes any plastic container would do since they don't need venting. I just thought something would already exist to fit that exact size.
As such, I wouldn't bother with the power center upgrade if I were in your shoes and looking to upgrade to LiFePO4. Just get a quality high amp charger like the Victron IP22 (30V) and wire it in for a much better experience and faster charging.
2022 T@b 320 S / 2021 Subaru Outback
I just bought a 2nd LiFePO4 battery (total 200Ah) so now I need to figure out a box for the set
So, no actual box would be necessary, especially with lithiums. I'd look to the off roading world. Something like: https://barnes4wd.com/products/barnes-4wd-dual-odyssey-pc1500-group-34-78-group-24-battery-box Using tamper proof Torx would help somewhat with theft protection.
