Hi..We purchased a 2022 Ultimate Camper by Ultimate Toys and it is manufactured by NuCamp. We owned a Airstream Bambi when our kids were small and this is our empty nester camper. This is our 2nd trip...found a few snafu's on the maiden voyage and had them fixed. This weekend we are taking it up to the Angeles Mountains at 7K ft. and no electricity at the campground. Bringing warm sleeping bags in case we don't figure out the quasi boondocking situation.. Any tips are welcome. Also hoping our small suv can pull it up the mountain. This looks like a great place to figure things out.
2022 Ultimate Camper by Ultimate Toys - Manufactured by NuCamp
2021 Hyndai Santa Fe Limited
Southern California
2 ·
Your UT-teardrop also has a factory installed Solar panel so with care managing your electrical usage you should have enough battery bank to run the Dometic Heater's Fan.
UT-teardrop information in the public literature lacks details on trailer gross weight, battery type/size, solar panel size, etc. So you will have to do some research to learn the "as purchased" performance of your new trailer.
There should be a sticker/label on the trailer stating the allowed payload; water, food, stuff, etc That can be added to the dry weight.
If your Santa Fe has the high-output, G2.5 TGDI, engine it is rated to tow 3,500#
If you don't have the TGDI then the tow rating is in the 2,000 to 2,800# range depending on other vehicle features.
The Santa Fe owners manual also states:
- A - Do not tow at speeds above 60 MPH
- B - On long steep hills do not tow above 45 MPH
- C - Hyundai recommends a sway bar be used.
Side Note: With the wider width of the UT-teardrop, tow mirror extensions could be helpful.
- D - Hyundai notes engine output drops with increased altitude.
They say your Tow Rating drops 10% for every 1,000 meters of elevation.
Your 7,000# mountain trip is just over 2,000 meters elevation.
So the max TGDI engine rating of 3,500# drops to 2,800# for best vehicle operation.
That drops your trailer payload to about 350#
None of the above says you cannot go to the mountain - - - just be aware and informed on how towing with your Santa Fe will change the performance.
Southern California
Southern California
Southern California
Your battery will try to get you, as was said , so be aware! A multimeter is the best, just not fun for many.
Volvo XC-40
SF Bay Area, California
Volvo XC-40
