External door grab bar - removal?
Chiprchuk
Member Posts: 23
The grab bar on the outside of our 2019 320s Boondock door is pretty rusty. So, I tried to remove it for sandblasting and painting. I removed the screws but the thing won't budge. Has anyone removed one? Is it epoxied on or?
Tab 320-S Boondock Edge 2019
T/V Ford Ranger 2023 4x4
I've removed the standard white plastic handle.
It was held by screws and a double sided tape.
Heat might relax the tape + you could ask nüCamp for suggestions.'18 320 S, pitched axle, 3020HE; PNW based
I also removed the white plastic handle from my 2019 320 CS. After removing the screws I had to gently pry it off. There was a sealant / caulking material holding it on. The sealant easily peeled off and cleaned up before attaching a newer and larger black handle. One of the 4 screw holes needed some work before attaching the new handle. I applied a new layer of clear sealant as well.
Camper - 2019 T@B 320 CS, TV - 2021 GMC Canyon Diesel
Scott & the S.S. PorT@Bella
My Teardrop Mods https://georgianwinds.wixsite.com/teardropmods0 -
I sent a note to nuCamp support and they advised they do use double-sided tape and sent this link
https://www.youtube.com/watch?v=KEbOheeHe3A to review how best to remove it. Thanks Everyone! Tab 320-S Boondock Edge 2019
T/V Ford Ranger 2023 4x41 -
georgianwinds Where did you get the new black exterior handle? Have a link?
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
"Our favorite trip will always be our next one"0 -
We replaced the clear lucite handle on our 2018 TaB400 with the new TaB Boondock grab handle. Works quite well. The top screws covered the original mounting holes, and the lower ones were covered with stainless steel screws
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
- 962 Air Conditioning & Refrigeration
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 919 Tips & Tricks
