I recently installed 2 lifepo4 batteies with the technical help of this forum. Lion Energy UT 1300's, DC-DC charger, & a WF 8735AD charger. Everything seemed to work fine. Batteries charged to 100% prior to camping trip. Gone camping for 5 days with no hookups. Batteries did fine, when traveling home the batteries charged back up to apprx 80% through the dc-dc charger. Got home & forgot the frig was left on. Had no solar, which I found the + terminal from the panel to the solar charger had come out of it's socket. Reinstalled all is good. In the mean time the batteries shut themselves off due to being drained. I plugged in the 110ac 30 amps, However my charger never came on to recharge the batteries. Does anyone have any thoughts on what may have happened & what to check? I did check all the fuses in the system & they check good.
2021 T@b 320S Boondock
TV - 2008 Toyota FJ Cruiser
Retired aircraft mechanic from AA
2-3 several week trips per year & other trips we can squeeze inbetween our long trips.
Avid road bicycle rider. always carry a bike or 2 with us.
0 ·
1- Is the DC-DC Charger only getting input voltage from the 7-Pin or
does the WFCO 12VDC Output also connect to the DC-DC Charger input side.
This is the DC-DC 'smarts' are controlling the battery charge not the WFCO.
2 - What is the WFCO 12VDC output reading when on Shore Power.
With and without the Battery Cut-Off Switch in both on & off.
If you are not getting any charge to the battery (i.e., via solar or the converter), then it must be something else. Usually a fuse, but you indicated they are good. Did that include checking the inline fuse(s) at the batteries?
If the above suggestions are not the issue, since you did a recent install/rewiring, maybe check for a loose wire somewhere, especially a ground wire, such as in the junction box on the frame at the front of the trailer.
2) The disconnect is not in the off position, My shore power is good coming into the charger, this I confirmed. Bayliss said:
I will check the output, but I fear it is 0 due to the fan is not running & when the unit is charging the fan will be on according to the WFCO manual. But I will definatly check this.
I agree with you and my solar is wired directly to the batteries, I did'nt have a chance yesterday to pull the camper out of the garage to confirm charging & it is cloudy & raining here today.
I am going to hook the tow vehicle back up & confirm if I can still get power from the DC-DC charger to charge, if so this will confirm the batteries are taking a charge, if not then I do beleive the problem would lye in the batteries. I did a quick assesment of my connections yesterday, I will do a more thorough look at them today.pthomas745 said: Thank you for the links I will read them prior to going out to the camper & checking all the above.
Thanks to all 3 of you, you have given me a good bit of info as to where to start.
I also recieved a setting sheet from Lion Energy yesterday for the victron settings. These setting are different from what I had set the parameters for the battery , both for V-712 & the Mppt solar charger. I reset these parameters for both. Lion Energy explains that my state of charge from the V-712 may not read correctly and these new settings should help that.
Thanks for all your help. I know that I should always check the simple stuff first, which I thought I did yesterday. 40+ years experience of an aircraft mechanic and I did not do a thorough first step.
