T@B 400 2021 Bathroom Fan Not working.
Sydmargo
Member Posts: 28
I checked the small glass fuse and it is good. Where do I go from there?
Do you have the small circular fan?2021 400 BD
2020 Tacoma TRD Off-Road -
If it's the old-style fan that sounds like an airplane propeller spinning, change the switch out, I used a toggle switch as a replacement. The switch that was originally installed is prone to failure. Not long after I changed the switch out the fan blade came off the spindle and I had to glue it back on, eventually I the dealer change out the entire fan under warranty.
2021 T@B Boondock 400. 2021 Toyota SR5 V6 -
@Sydmargo, assuming you also have a ceiling fan in the main cabin area, is it working? If not, maybe the fuse blew there and (assuming the two fans are on the same circuit), that would prevent power from flowing to the bathroom fan.
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Our circular Maxxfan had an issue where the button wouldn’t stay depressed. It kind of fixed itself after I pulled it out and apparently did something to get it to work. Not sure if that’s your issue.2021 400 BD
Same thing happened to our daughter's 400. New switch fixed the glitch. You can test if its the switch by jumping a wire between the terminals on the switch. If doing so causes the fan to run (watch your fingers), then its the switch.
2014 T@b S Max AKA T@dpole -
@Sydmargo - https://tab-rv.vanillacommunity.com/discussion/16307/for-sale-used-dometic-ez-breeze-ventilation-fan#latestSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
