T@B 400 2021 Bathroom Fan Not working.
I checked the small glass fuse and it is good.  Where do I go from there?
  • manyman297
    Do you have the small circular fan?
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • Sydmargo
    Sydmargo Member Posts: 28
    Yes
  • RayJim
    RayJim Member Posts: 148
    edited December 2022
    If it's the old-style fan that sounds like an airplane propeller spinning, change the switch out, I used a toggle switch as a replacement. The switch that was originally installed is prone to failure. Not long after I changed the switch out the fan blade came off the spindle and I had to glue it back on, eventually I the dealer change out the entire fan under warranty.
    2021 T@B Boondock 400. 2021 Toyota SR5 V6
  • Bayliss
    Bayliss Member Posts: 1,535
    @Sydmargo, assuming you also have a ceiling fan in the main cabin area, is it working?  If not, maybe the fuse blew there and (assuming the two fans are on the same circuit), that would prevent power from flowing to the bathroom fan.
    Greg & Marlene (Tucson, AZ)
  • manyman297
    Our circular Maxxfan had an issue where the button wouldn’t stay depressed. It kind of fixed itself after I pulled it out and apparently did something to get it to work. Not sure if that’s your issue.
    2021 400 BD
  • ChrisK
    ChrisK Member Posts: 282
    Same thing happened to our daughter's 400. New switch fixed the glitch. You can test if its the switch by jumping a wire between the terminals on the switch. If doing so causes the fan to run (watch your fingers), then its the switch.
    2014 T@b S Max AKA T@dpole
