While I was adding the three exhaust fans and fan thermostat, I tried hard to find ways to make sure that the air drawn in by the fans was actually helping to cool the condenser fins, rather than just passing by.
There's a fairly wide space between the top of the fridge-face, and the birch trim.
I wanted to plug that gap to redirect the cooling air across the condenser fins.
I found some leftover soft rubber weatherstripping that fits perfectly, tapers well (the gap width is uneven from side to side), and is removable for winter camping (when the heat is welcome to stay inside the Tab).
It's the stuff that has this profile, with a sticky side, which I left the paper on so it wouldn't stick. Home Despot carries it.
Even looks pretty good!
Chan - near Buffalo NY
Would probably work in the gap below the wall mounted AC also. In a strong wind, hot/cold air blows in there also.
I think the only real way to prevent that air infiltration is with the outside AC cover, because there's a big hole inside the AC box, which goes directly into the shower wall cavity.
Air actually blows right down that cavity and into the bench seat, and around the shower pan into the wall where the pump sleeps, and into the kitchen cupboard!
If you can feel drafts around the bezel of the AC unit, then I betcha you'd feel it in the bench seat too.
Unless of course LG addressed that hole in there before yours came off the line.
A better fix would be to plug the hole inside the box, and weatherstrip it, as you say, and maybe insulate the inside of the box too.
But that becomes another endless project....
Come to think of it, one might be able to get at that hole from behind the mirror in the shower...
Hmmm. I'll be sure to post pictures. :-)
