Fresh Water Level Display
jbajor
Member Posts: 233
I just returned from an over night trip… I filled my fresh tank in my driveway until it overflowed. Indicator showed full. I drove to destination, leveled camper and spent the night. I used very little water and in morning indicator showed one led. Grey water showed the same. Yikes, how could I have lost lo much water? Leak? I just got home and parked camper back in driveway. 3 leds! ( two for grey) What the heck? Where is sensor located? What else can affect it? I cannot believe it can be this sensitive to being slightly off level?
cheers!
cheers!
Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California
Volvo XC-40
We are not familiar with the Ultimate Toys Camper tank monitors. Can you show us a picture so we are all on the same page? NuCamp originally used SeeLevel with external sensors, then went to a different monitor with internal sensors. Both can be fiddley. Depending on your level, you can add more water to a tank, or it will show “full” when there is more room available.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
It is identical to a tab 320 (built by nucamp)Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California -
here is a photo of the display unit.....
Volvo XC-40
@jbajor I did a quick edit of your photo, so I hope you don't mind. I can't hold my neck that way too much anymore!
The KIB tank monitors (and the SeeLevel monitors in my 2017) are a bit different than I though they would be. Skim through this video a bit and have a look at what the tank monitor sensors are and what they are trying to do. It may be just a trailer trying to break itself in, but if the terrible readings continue, someone may have to take a look at the sensors.
Towed by 2014 Touareg TDi -
Thank you so much! super useful! Cheers! JordanUltimate Toys Teardrop Camper
Volvo XC-40
Thank you again for the Video! Knowing how it is wired has me suspicious of a bad ground at the terminal block of the KIP panel to the two tanks... Opening panel to check Cheers!Ultimate Toys Teardrop Camper
Volvo XC-40
Good, let us know what you find!
- 920 Introductions
- 74 Teardrop Groups & Links
https://www.youtube.com/watch?v=F-u6B0e9vsQ
