I just picked up my 2023 400 with 1 lithium battery. Can't find any reference to the battery heater switch in the online manual (didn't get a printed manual!!). If I am connected to shore power at night with close to freezing temps do I need to have the battery heater switch on? Is the battery being charged from shore power? If so, is the battery damaged by not having the heater on?
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
0 ·
As per Battleborn, the BMS is set to disable charging below 25 F, as charging can cause serious irreversible damage to LifePO4 batteries. However, discharging at temperatures below 25 F will not cause any damage.
When we had our 400, I had 400 Ah of Battleborn under the bed, a Victron Smart Shunt with a temperature sensor, there was never any danger of the batteries being too cold while using the camper.
So, the only time I could imagine ever using the heater would be if I lived in a very cold climate and was planning to use the camper. I would possibly need to use the heater(s) until the interior temperature (specifically under the bed) was above 25 F. Since the Alde is also under the bed, the temperature will rise pretty fast, and remember the BMS is going to protect the battery anyway. Chances of actually using a TAB below freezing is not very high unless you have done some modifications. They are not insulated that well, and are very slow to get very warm once the ambient is in the low 30's.
During storage, Battleborn recommends a state of charge above 50% and disable any charging or draws. So, Perko off and the Solar Charge Controller (if equipped) off, and no cord to shore power.
In my opinion, NuCamp chose the heated version due to the 320 series and batteries not in a heated compartment Rather than stock (or buy) 2 different models, it was simpler to stick with a single SKU.
Brad
Concord, NC
If you didn't have the heater function on while traveling in really cold temperatures, there's the potential for your battery to turn off discharging causing you to lose your emergency breakaway brakes.
Recently I've been trying to charge mine overnight and temps dipped below freezing, so I flipped the battery heater switch.
In your "goody" bag from nuCamp, you should have received a couple brochures from Battle Born including one for the heating function.
Sold 2023 Tab 400
Sold 2018 T@B 320S
I think this is a good theory regarding "one SKU" for NuCamp. So here's a question . . .
If I'm looking to upgrade my 2023, is there any reason why I, personally, should be inclined to spend an additional $225 ($75 x 3 batteries) to get heated BattleBorns vs. unheated?
Any time you feel there is a chance the temps could go below zero while charging then go ahead and enable the battery heater. Don't worry, in the case of Battle Borns, when the manual switch is activated the BMS will not actually activate the internal heaters unless it's sensors determin it needs to.
So basically the purpose of the manual switch is an override to ensure the BMS won't turn them on and therefore draw any power when you're in storage etc. and not planning to charge.
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
Trips - 48 Mileage - 63,452
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
