My TV is a 2015 Mercedes-Benz GLK 250 (diesel). Plenty of power and good handling towing my 2016 320 S Max. However, I get significant longitudinal push/pull action on the TV from the T@B, especially at lower speeds on uneven road surfaces. Speed bumps are really exciting! Above 50 mph it diminishes quite a bit, but is still noticeable.
My prior trailer was a LG 5-Wide Platform with a dry weight of around 1000 lbs. including my added storage boxes, I never had this issue with that trailer. Given that my T@B weighs at least 700 lbs more, it likely that explains the difference.
I have tried to mitigate this issue by using a Curt RockerBall Cushion Hitch Trailer Ball, but don’t notice much difference. I have read that the RockerBall requires break-in for optimal performance and I have only used it for about 10 miles, so it’s still fairly virgin.
Has anyone else experienced this issue? How did you address it?
Do you have a tightener installed?
Adventures: 51 Nights: 322 Towing Miles 41,200+
2022 T@b 320 S / 2021 Subaru Outback
2015 Little Guy 5-Wide Platform
2015 MB GLK 250 (diesel) Tow Vehicle, "Benzie"
Sequim, WA USA
Three things made towing more comfortable for me: More weight on the tongue (12-15%). I went with a Convert a Ball hitch insert/ball mount, which smoothed things out somewhat (couldn’t get the height right with a Curt Rocker). And ultimately added a hitch tightener like MuttonChops uses.
https://www.amazon.com/gp/product/B0068D3WLW?psc=1
https://www.amazon.com/gp/product/B07JDD8L3H?psc=1
I will get one of these and try it out.
Sequim, WA USA
Minnesota and Arizona
Sequim, WA USA
But I don't think you are all set. I believe your 1 1/4" receiver is a Class I hitch, rated for up to 2,000 lbs. Would your Tab 320 weigh under 2,000 lbs when loaded for travel ?
Also, your Mercedes Diesel engine has plenty of power to pull your Tab, but is the chassis rated to pull it ? Can you fit a larger hitch receiver if needed?
The other thing I was thinking about was the front to back level of the Tab when hitched up. Is it level or slightly nose down, that would be good. If it is nose high, depending on loading, it may not have enough hitch weight. This could cause some porpoising which may be felt as longitudinal push-pull. At higher speeds the wind will keep the trailer pushed back, mitigating the effect.
But then, as they say, never believe anything you read on the internet. So take the time to learn good towing practice, and experience is the best teacher.
Here is an article with the same vehicle towing a 5500 lb Airstream. Not recommended!
https://www.rvlifemag.com/towing-test-mercedes-glk-250-bluetec/
Sequim, WA USA
Don't try this at home unless you know what you are doing.
"Just Enough"
Noting the GLK 250 is eight years old, the shock absorbers could be worn and unable to control the movement of the extra weight on the vehicle.
I don't know what you carry in your car, but people often load the back heavy without regard for individual axle ratings. Then drop the trailer tongue onto it as well.
And even though the car is rated to tow 3500 lbs, any weight carried inside the vehicle reduces that capability by whatever weight is loaded inside. Sometimes this is evident in the tow vehicle's GCWR (Gross Combined Weight Rating), which includes loaded tow vehice and loaded trailer.
If the problem persists, you may want to check your shock absorbers for function under load, and do some weighing at a Cat scale.
Sequim, WA USA
The ball mount's tightness in the receiver is still suspect. Maybe just force a large hardened washer in the gap until the slop is gone as a second part of the test.
@Binghi, good thought. I actually have 3 ball mounts (one Reece and two Curt) of differing drops. They all seem to fit similarly loose in the receiver tube, so maybe my tube is out of spec. I've only towed a couple thousand miles with this TV, and I doubt the previous owner did much. The paint on the hitch looked untouched! I purchased a hitch tightener, but have not been able to go for a spin with the trailer yet. I'll post an update after a test drive.
Sequim, WA USA
Sequim, WA USA
