A FB member took some photos of the drains under the trailer. Seems to be a couple of changes, but I am no expert.
1. The low point drains, and tank overflow. Is this a new spot for the fresh water tank drain valve? And the overflow?
2. Alde Yellow Flapper drains. Dual Glycol drains?
3. Trying to sort out exactly where/what this is.
4 Air conditioner drain?
4. Don't know what this is.
While I cannot answer your question, you could do an easy test to decide . . . .
After your next trip
--- Use the Hot/Cold Low Point Drains
--- Then activate the two (if equipped) Alde Yellow Valves (one for furnace tank, one for extended HW)
What happened?
Did you hear or see on the ground extra water discharge?
to 're-fresh' the tank's air cushion.
