2017 320 CS-S leaking fresh water drain valve?
Noticed this summer 2022 but barely camped due to other travels.  Prepping for a stretch in southern New Mexico with friends.
Poured a gallon of fresh water in potable water tank; watched as some came out open valve, then closed valve.  Now seeping out behind valve - wiggling valve assembly neither increases or decreases drip.  Also a drip has started directly behind passenger wheel, a few inches behind this drain valve.
Experienced RV pal thinks fresh water tank probably OK, but drain tube (blue PEX) and/or drain valve needs work.
Anyone been down this particular plumbing road?  We are experienced dry tent campers, so have plenty of water containers and a half ton RAM tow vehicle, just unfamiliar with onboard water storage issues in T@B world.
(Bought Ruby used in 2021, was apparently a dealer rental before previous owner bought it before selling it to us.  Had to replace the trailer brake controller fall of 2021 - handy on southern Colorado highways! - but otherwise pretty good shape.)
