@MuttonChops ... Thank you for your work creating the 2022 Tab 400 wiring diagram! That is a great resource and it will be a permanent part of of my reference library. That, along with other posts and photos, has been a big help in my reading/learning/planning a Victron SmartShunt and 2nd SmartSolar MPPT 75/15 charge controller installation in a few weeks once we get our 400 back from storage.
If you make any updates to the wiring diagram, can I kindly suggest the following:
1. If a shunt is installed, it should instead go along the black wire between the battery and Distribution Studs. Where it is shown now would not include the charging from the factory solar charge controller, or the load used by the inverter.
2. It would be nice to show the stand-alone mounted (Stinger?) (150A?) fuse (along the red cable from the Distribution Studs to the inverter).
3. The red wire battery connection to the factory solar charge controller instead goes to the Gloso breaker (battery-side), not to the Distribution Studs. While this doesn't make any difference electrically, placement at the breaker allows the inline (30A?) fuse to be more accessible for checking/replacement, in the outside storage compartment, where the breaker is.
4. It would be nice to show that inline (30A?) fuse for the solar charge controller, mentioned above.
5. Probably just too big an ask, but ideally, wire sizes might be shown on the diagram too. But, there are probably just too many dang wires for that, LOL. The ones relating to my upcoming installs...so far I'm guessing that battery & inverter cables might be 4AWG, main supply wires to camper might be 8AWG, and wires to solar charge controller might be 10AWG....but I'll find out in a few weeks when our 400 comes out from storage!
Thanks again. Cheers
