No more removing screws and the panel to check my Glycol.
SLJ
SLJ Member Posts: 650
No more removing screws and a panel to check or fill my Glycol reservoir behind the toilet in my 2021 T@B 320 S.
Added a 6" hatch. EZPZ now.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
  • SLJ
    Used a 6 1/4" hole saw and this: https://amzn.to/3ZrQnvP
    2025 Ford Ranger
  • Tabmanic
    Tabmanic Member Posts: 36
    That's really clever. Great idea! way better than taking the panel off for sure, Nucamp should be doing this.
  • Tabaz
    Tabaz Member Posts: 2,420
    Tabmanic x2!
    pthomas745 Administrator, Moderator Posts: 4,587
    Can you come over and rework my 2017 tank area so I don't have to bend like a pretzel to even see it?
  • BrianZ
    BrianZ Member Posts: 1,770
    @pthomas745, Have you seen how I made ours easier to check without unscrewing the panel?  It has a light switch & peephole for a quick view of the glycol level..
    @Brianz yes, I even had that post bookmarked and forgot it.  I've been thinking about the glycol exchange recently, and that was what made me comment here.  Thanks!
  • CharlieRN
    CharlieRN Member Posts: 436
    A very clever solution @SLJ! My fix was far less elegant, but a bit simpler.
    I replaced the screws holding the panel in place with three dowel hangers. The panel is now held by stainless cap screws (with washers), making removal a bit easier, though still requiring tools. I actually posted photos of the mod here on the forum, but failed to bookmark them.
  • BrianZ
    edited April 2023
    Almost forgot..  Nice job, SLJ!  Gee, that port hole looks familiar to me for some reason.  🤔
    Also, thanks for reminding me that I had forgotten that I intended to improve access to our own glycol tank.
  • jesserevilla305
    jesserevilla305 Member Posts: 1
    New to the group and appreciate the insight into using the Aldi system. My question. Once you remove the board behind the toilet to have access to the Glycol reservoir. The exterior seals come off and are hard to place back. And if you want to rinse down with a shower head; I doubt one breaking the seal will stop water from entering.  Please any suggestion other than Not Take A shower lol
    @jesserevilla305 - see above thread to see how you can access the glycol reservoir without removing the wall panel.
  • bjn2
    bjn2 Member Posts: 123
    @SLJ I bought a port and intend to follow in your footsteps. This will be in addition to the flexible plastic mirror I already installed to make it easer to see the level in the reservoir.
    Utah-based
    2023 T@B 320 S Boondock
  • RalphD
    RalphD Member Posts: 4
    Did the same on mine. Great idea.
