Readings the above indicates the very basic connections will be: (plus in-line breakers, fuses, ??)
Multiplus is directly under the passenger side of the trailer below the seat cushion.MuttonChops said:Please clarify the location of the Multiplus . . upper picture.For lower Picture what are you 'highlighting' ?P.S. thanks for the pictures.
Found it - - - On right of picture, at older access door location.
The breakers are also switches. The two square ones are for the batteries. I can switch each battery off individually. The rounder one on the right is coming from the charger. My main disconnect for everything is on the left. Here's the schematic.pthomas745 said:@SLJ, in your setup, you use several of the circuit breakers. I'm guessing the two breakers are in place of regular battery fuses for convenience? And, what is the purpose of the breaker over on the right side? Just curious. I can barely crimp wires very well, so I'm always impressed with this sort of install.
More pictures are always a positive even if showing 'same stuff' but from different angles and 'zooms'.
Well I didn't think that there were too many out there with a 2023 with the factory lithium package but I thought that I would give it a try anyway. The multiplus manual is where I discovered the ups function but unfortunately it is not very detailed and what I posted is all that I gathered from it. Might have to give Victron a call.pthomas745 said:@jamesdn1948 one of the reasons this thread was started is...we don't know what we don't know. Only a few owners have checked in and gave us help with where everything is and the basics of how things work. So, any information you can provide about the UPS function is useful. (I think we need to dig into the Multiplus manual!)
reilersjr said:
Can anyone confirm that there is no WFCO charging circuit in the 2023 320s Lithium package?
. . . traced the hot wire from the 7 pin trailer plug to the junction box(where it changes color from black to red) then into the camper to the back of WFCO distribution panel.
