Those of you that have digital Alde control panels (I don't), what is a typical glycol temp when the system is actively heating?
2016 T@B 320 M@X S "Annie", 3rd Owner
2015 Little Guy 5-Wide Platform
2015 MB GLK 250 (diesel) Tow Vehicle, "Benzie"
Sequim, WA USA
0 ·
Technical Specifications {seen published in two different documents}
++ Max System Temperature: 176°F [ 80°C ]
2020 Tacoma TRD Off-Road
Trips - 48 Mileage - 63,452
I'm betting the temperatures are different all over the loop. If you took the temperature in the jug, it would be really low due to poor circulation. The fluid in the radiators are constantly losing heat to the cabin. The highest point is probably inside the boiler.
The water temperature you select on the second line of the controller will change the glycol temperature. So will your choice of heat source. When heating water but the temp is turned down to disable the pump, the radiators are cold, at least the ambient temperature.
What are you trying to do? Just curious is a valid answer. I've been curious about a few things too. ; )
"Just Enough"
I'm re-plumbing with 7/8" dishwasher drain hose. It has a maximum temp of 180 degrees, maximum pressure of 120 psi and is made of the same EPDM material as the original. It is readily available locally at a plumbing supply house and is only $3.08/foot -- less than half the price of automotive heater hose, less bulky and more flexible. I have not been able to get a price on the Alde hose, but UK sites suggest it's about £23/meter, though I found nobody that had it in stock. My manual says the boiler over-temp cutoff is 185 deg, so I doubt the glycol ever gets past 180. It would be an exceptional scenario in any case and since the pressure in the convector loop is near zero, it should work just fine.
I'll post somewhere on the forum once I have completed the reassembly.
Sequim, WA USA
I thought the maximum temperature was 184 or 185. I'm sure that is an emergency cutoff. That's why I suggested automotive heater hose. An engine coolant routinely is 210 to 220. Heater hose is pretty stiff. I guess you could use heater hose for the run from the boiler to the first radiator. Then switch to domestic water line. I'm sure there is more than 5 degrees drop across a radiator.
Let us know how it works out. Good luck.
"Just Enough"
