I’ve just noticed a bit of water dripping from the bottom of the trailer. Tracked it back to this valve going to the Alde system. It looks this is the source since there is water around it but I’m not 100%.
Anyone had a similar issue? What would be the best course of action here?
If the leaking water is dripping out of the associated drain tube below the trailer, it’s possible that the valve is functioning properly.
The valve on my trailer sometimes drips a little bit of water out of its drain tube when I turn on the Alde, causing the water to heat, expand and build pressure.
If the water leak originates elsewhere in the valve assembly, a different set of circumstances may be at play.
Were you connected to a utility water source (e.g., at a campground or your house)? If so,
did you have a a pressure regulator (40-50 PSI max) connected between the campground spigot and the trailer? Without a pressure regulator, too much water pressure can be sent to the Alde tank and cause it to leak, particularly at the pressure relief valve, which would be doing what it is designed to do in that situation. (Whether it would also leak inside the trailer due to unregulated pressure, I don't know - - - a leak inside would tend to indicate a faulty valve.) NOTE: The safety relief valve is designed to open at 50 PSI.
If you were using water from the fresh water holding tank, another possibility is the pressure setting on the ShurFlo water pump. It may need to be adjusted. There are discussions on the forum about how to do that. (This issue seems less likely if you have not had previous issues while using the water pump.)
2020 Tacoma TRD Off-Road
I also see I probably wasn't clear in my first post - there is a small water buildup around the valve and it ends up dripping under the trailer (that why I noticed it). So the water makes it's way to the side of the trailer and drips from the panels outside - so not where I would want water at any point.
Can you get a good look at the side to see if there is a water drop below one of the pex connections? If so, that would likely require replacing the valve and having someone experienced with pex connections to do the replacement.
I was was way off with my initial suspicions- turned out it was a connection that was loose (see photo)and just needed tightening. I’m surprised that I didn’t get more water before because in my testing I saw 2-3 drops per second. So quite a bit.
