2022 320 CS Stove not working
oxer5
oxer5 Member Posts: 2
edited May 2023 in Tips & Tricks
So I am not sure if I am doing something wrong or not
The stove is not getting any propane and I have seen discussions on this exact thing happening  with no  answers with a fix
I have tried disconnecting the tank connecting it
Slowly turning on the valve
Waiting 5 minutes trying again
Replaced the regulator
Still nothing
Does the alde system need to be on?
Next I am going to pull the stove to see if I get gas on that end
I do have  a extended warranty but it just cant be this difficult
Any ideas?
    Hmmm.  Does the Alde work on propane only?  If you have a gas grill, will the tank work on the grill?
  • Grumpy_G
    Grumpy_G Member Posts: 789
    edited May 2023
    Doesn't the CS have a safety valve that shuts off propane when the lid is closed ? The issue might be there.
    Edit: Just googled it, there is a switch at the left strut.
  • Marceline
    Marceline Member Posts: 1,779
    edited May 2023
    Still nothing
    Any ideas?
    The propane has to travel all the way from the front of the trailer to the back and I’ve noticed that if I haven’t used it in a long time it can take a while for there to be enough propane coming out of the burner for it to light. When you turn and push in the dial can you hear anything at all?
  • jbajor
    jbajor Member Posts: 233
    do you have propane flow out of the quick release in the back under the trailer?
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
  • Mickerly
    Mickerly Member Posts: 517
    The safety switch will shut off the propane to the stove. Make sure the propane is on. Push in on either or both knobs. If you don't hear gas from either burner, either the propane can is empty or the switch failed "closed."
    Turning on the Alde on propane or running something on the back outlet, if you have one, will ensure you have propane, the leak protection fuse and the regulator are good.
    2018 320CS-S
    "Just Enough"
