2022 320 CS Stove not working
oxer5
Member Posts: 2
So I am not sure if I am doing something wrong or not
The stove is not getting any propane and I have seen discussions on this exact thing happening with no answers with a fix
I have tried disconnecting the tank connecting it
Slowly turning on the valve
Waiting 5 minutes trying again
Replaced the regulator
Still nothing
Does the alde system need to be on?
Next I am going to pull the stove to see if I get gas on that end
I do have a extended warranty but it just cant be this difficult
Any ideas?
Hmmm. Does the Alde work on propane only? If you have a gas grill, will the tank work on the grill?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Doesn't the CS have a safety valve that shuts off propane when the lid is closed ? The issue might be there.
Edit: Just googled it, there is a switch at the left strut.1 -
Good thinking @Grumpy_G! Here is the thread about the LPG solenoid which may be defective.
https://tab-rv.vanillacommunity.com/discussion/11515/does-your-2018-and-later-clamshell-cs-have-a-solenoid-valve-for-propane-flow
The propane has to travel all the way from the front of the trailer to the back and I’ve noticed that if I haven’t used it in a long time it can take a while for there to be enough propane coming out of the burner for it to light. When you turn and push in the dial can you hear anything at all?oxer5 said:So I am not sure if I am doing something wrong or notThe stove is not getting any propane and I have seen discussions on this exact thing happening with no answers with a fixI have tried disconnecting the tank connecting itSlowly turning on the valveWaiting 5 minutes trying againReplaced the regulatorStill nothingDoes the alde system need to be on?Next I am going to pull the stove to see if I get gas on that endI do have a extended warranty but it just cant be this difficultAny ideas?San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
do you have propane flow out of the quick release in the back under the trailer?Ultimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California0 -
The safety switch will shut off the propane to the stove. Make sure the propane is on. Push in on either or both knobs. If you don't hear gas from either burner, either the propane can is empty or the switch failed "closed."
Turning on the Alde on propane or running something on the back outlet, if you have one, will ensure you have propane, the leak protection fuse and the regulator are good.2018 320CS-S
"Just Enough"0
- 968 Air Conditioning & Refrigeration
