Anyone know the wire color and location for Boondock backup lights?
2019 320s Boondock Edge. Trying to connect the existing backup lights to the 7 pin so they come on when TV is in reverse. They currently operate via a switch.
Does anyone know the location and wire color of the wiring for these lights? I’m good on the J box side. Just need the other end.
TV is 2007 Kia Sorento EX with 3.8L engine
  • Bayliss
    Bayliss Member Posts: 1,534
    @crosstrnr, I can't answer your question (although the usual standard color at the seven-way plug connection is yellow, but I have also seen purple), but I am curious if your 2019 320 S came with reverse lights from the factory.  Mine did not, and I am not aware of any having them in that model year.  I am also curious where they are located.  Maybe you can post a photo.  Thanks!
  • crosstrnr
    crosstrnr Member Posts: 24
    @Bayliss, Here you go:
  • Bayliss
    Thanks, @crosstrnr, I now see what you are referring to............the lighting included as part of the Boondock Edge package, which I am familiar with, but did not purchase.
  • SLJ
    SLJ Member Posts: 668
    Should be the center pin coming off the 7 pin connector. Not sure it's actually connected to anything in the junction box under the tongue or for that matter, tow vehicle.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • rfuss928
    rfuss928 Member Posts: 1,197
    Can you look at the back of the switch and check the wire color there?
    MuttonChops Member Posts: 2,085
    edited May 2023
    Nice,  I have  not seen that before.   Is it factory or (previous)  owner installed?
    As for the wiring, switches must be connected to the Fuse Panel.
    My guess is; You would need to run a new wire from J-Box to light side of the Ext Rear Switch.
  • Grumpy_G
    Grumpy_G Member Posts: 789
    Just a thought but I prefer the manual switch backup lights the previous owner (@Dalehelman ) installed. Otherwise if you're pulling forward  trying to adjust the angle you don't see when the trailer is lined up.
