Hello everyone.
I have recently purchased a 2022 tab 320 boondock.
I have noticed my floor starts to bow in the middle when I fill my fresh water tank. It is very noticeable starts to make popping noises as it warps. When I look under the trailer the material that covers the bottom is also all warped. I am assuming this is caused by the fresh water tank ballooning up.
When I try to drain using the freshwater low point drain it only drain about 1/4 of the tank. I’ve tried different angles but makes no difference. I’m guessing this is a venting problem.
I was just curious if anyone else has had this problem.
The only way the tank can deform is if that overflow drain is somehow clogged which wouldn't allow air or water to escape...but you'd also not be able to fill the tank much due to the trapped air.
2020 Tacoma TRD Off-Road
the only way I could get the rest of the water out was to use the faucets. The floor went back to normal when the tank was near empty.
Winner winner chicken dinner. The dealership just called and said the drain tube was clogged with mud daubers. They were so far up the drain tube they had to disassemble it to clear it out. Could not see the clog by just looking underneath.
Our 2021 320 boondock fresh tank cannot be fully drained after two hours via the 1/4" I'd side Brass valve. Mounted too high and tank belly is deformed hanging below the two 1" strap supports.
Would practically have to stand camper on end. We are forced to pump tank contents to Grey water six or eight complete flushes taking half a day, to achieve reasonable dilution of remnant polyethylene glycol, and only drink pitcher filtered water.
Nucamp needs to mount a full 3/4 ID bulkhead tank drain, bottomside, and properly support tank with continuous angles.
See photo- why did they buy and install two curved strap supports designed for a barrel tank, on this square flat bottom tank? (N.B. the aluminum angle in photo is sixteenth gage and only serves to attach bottomside corrugated scrim. Tank sits on axle.)
Likely the cause of tank sag and glycol retention on a great many owners campers.
One of dozens of design/installation defects on our model year.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
