I've been trying to understand why if I don't open the door for 8 or 10 hours why it comes on so much. I've used a thermal camera on the door seals and see no cold escaping. I've pulled it out of the cabinet to see if any holes into it aren't well sealed and didn't see anything. It seems very well insulated.
I usually keep it on a 3. It keeps everything cold. Independent of how well or efficiently the compressor or fan is working or what cold setting its on, I don't understand why it needs to come on so much. Where is all the cold going? Does the refrigerant thermosiphon it away then when the compressor doesn't run or something? I really would like to know what the design issue is and if it can be overcome somehow.
2019 Nucamp Tab 400, 2007 Toyota Tundra 4.7L, 4wd SR5
0 ·
I have a refrigerated cooler that rarely cycles once it's down to temp unless the door is opened. I've seen insulated 5 day coolers keep ice cubes unmelted for over 5 days sitting outside on a hot porch in the summer. Both of these things have similar insulation as the Norcold, so I just want to understand how it loses so much cool.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
GDSTIME 50mm USB Fan, 50mm x 15mm Blower 5V DC Brushless Cooling Fan https://a.co/d/bQy846x
I recently installed a dual fan system in an enclosed cabinet of my entertainment center, which contains a TiVo DVR and an NVR security system video recorder. Neither produces a lot of heat, but I did need to supply some air circulation since the cabinet is fully enclosed (other than slight openings around the cabinet doors.) I like the system (which is AC powered), because one fan blows air into the cabinet, while the other blows air out of the cabinet. The system includes a digital panel and a thermometer probe that turns on both fans when it reaches the temperature setting I selected.
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
Anyway I recently started setting the dial to 2.5 instead of 3 when I'm on batteries and it seems to run way, way less. I'm also going to start putting ice packs in the freezer when I'm plugged in our when solar has my batteries mostly topped off. Then move them into the fridge compartment when it's overcast or shaded.
I'm hesitant to put meat in the freezer at that setting. I need to just get one or two wireless thermometers.
I noticed the Isotherm fridges have the compressor and condenser coil on top instead of underneath. That makes more sense for placement to me.
Ontario, Canada
2018 Tab 400
Donald S. Cherry - 2016 Kia Sorento V6 (3.3L)
Where we call home - Our House, Calgary, Alberta, Canada, North America, Earth, SOL, Milky Way, Universe
GO FLAMES GO!
By the way, Accurite has a battery powered thermometer with 3 remotes. We leave one in the 'fridge to monitor and one on a stabilizer jack for an outside reading.
"Just Enough"
the noise of the fan and compressor are not very noticeable to our ears.
That was part of the reason we changed out our Danby air conditioner. We have one with a thermostat now. Much nicer.
"Just Enough"
