After learning about the alarm setting that was frequently turning my Jensen on while parked at home (solved), I am trying to solve why the radio constantly robs my bluetooth signal from other nearby devices while parked at home and turned off.
My phone will be connected to garage radio or a speaker and every few minutes the Jensen will connect automatically and disrupt the stuff I am listening to. The phone will show 2 devices connected, I disconnect from Jensen, restart my program, and a couple minutes later it will connect again.
Anyone else experience this, a forum search suggests no.
0 ·
Southern California
Full-timer since 2019
2020 Tacoma TRD Off-Road
From the manual: Bluetooth Menu Options
NOTE: Please note that some Bluetooth menu options are only available while the unit is in Bluetooth Audio mode.
Press the SETTING button (23) to enter menu adjustment mode. Repeatedly press the >>| or |<<buttons (5, 2) or SETTINGS button (23) to access the “Bluetooth On/Off” menu function. Rotate the volume encoder knob to select BLUETOOTH ON, the press the ENTER button (4) to turn the Bluetooth function On or Off. The following additional menu options are available when the unit is in Bluetooth mode.
https://www.asaelectronics.com/support/
Hopefully you’ll be able to find a setting to turn off BT when you’re not using it.
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
Still learning to dry camp after a couple years of light use.
https://www.amazon.com/gp/product/B012IJ35VQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Over head round LED lights were changed to dimmable with no power draw when off. Check here for my mods so far: https://teardropsandtinycampers.com/sj-mods.htm
2025 Ford Ranger
