Alde control panel not working
We have a 2021 Tab 320 and the Alde control panel has stopped working. I replaced the fuse on top of unit, but still it doesn’t work. Can someone please offer some other troubleshooting advice. If the control panel does need to be replaced what might be the cost to do so? Thank you very much!
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,484
    Welcome to the Forums...
    The Fuse was the first obvious thing to try.  In the Alde 3010 (pre-2018 Alde) the fuses were known to blow. Not so much in the Alde 3020's.
    When you were looking around at the fuse holders, did you have a close look at the other connectors and plugs in that area?  Here is a quick description of what is what and what they do.  Check the "ethernet" looking connector.  Look at that cable closely, because it is the one running to the back of the control panel.  It may be necessary to take the panel off the wall and have a look at the cable behind it, too.
  • BrianZBrianZ Member Posts: 1,769
    Wondering if you found the problem, @kala406?
  • Yoshi_TABYoshi_TAB Member Posts: 564
    edited June 2023
    Hi,  Are you running on shore (110V) power or battery power.  The other things I would check are the power sources/breakers and fuses for your main power supply to confirm you have the correct power requirment (AC or DC) and no fuses or breakers for the main power supplies are tripped or blown.
    2025 360 CS
    Southern Maryland
  • kala406kala406 Member Posts: 2
    I have checked all fuses and breakers and they all look good. I have good connectivity at the 12v power supply on top of the heater. The red cable is in good shape at the heater and behind the control panel. It looks like it is pointing to a new $425 panel. Thanks everyone for taking the time to try to help. Hopefully I will have good news after I replace the panel.
