I will be installing a Victron Orion dc-dc charger in my 2023 T@B 400 BD with the lithium upgrade and the 3k wat Victron inverter/charger. I asked NuCamp customer service for a wiring diagram to plan out the installation but they said they couldn’t provide one. My plan is to route the positive and negative outputs from the dc-dc charger straight to the respective terminals. Just checking to see if there's any problem with that plan.
0 ·
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Jericho, VT
How are the brakes getting power if the trailer gets disconnected from the TV in your case (i.e. emergency brake pin gets pulled out) ?
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Jericho, VT
Jericho, VT
The move was pretty easy as I just put the DC-DC at the other end of the wire to the WFCO output (battery). If installing from scratch it will be a matter of finding the red and white wires which run from the 7-Pin back to the WFCO battery terminals (the white goes to the terminal block). That is what you put on the INPUT to the DC-DC and then run the DC-DC OUTPUT where the input wires originally went. You still need to get battery voltage to the break-away switch. I used +12V from the DC outlet (15A fused) for this.
The settings for the DC-DC are a bit tricky and not neccesarily intuitive! With a large voltage drop to the input you have to carefully consider the settings which determine when the tow vehicle is running or not (so as not to charge when the TV is connected, but not running and deplete its battery).
Jericho, VT
I'm waiting to get a bit more life out of my Lead Acid AND retirement to move to Lithium tech and bring the batteries and charger into the trailer.
managed by VE Smart Network
This was helpful along with my lithium upgrade. After the upgrade with victron 3000w multiplus, I pulled out the guts of the wfco in the lower part of the fuse compartment and put the dc dc Orion and a trak4 GPS tracker in the now empty space and followed your wiring for keeping the breakaway battery powered and separating the tv power to the Orion and than (output) to the battery system (40amp connection) . Thank you!
