I am adding a Renogy 100 watt panel with 20a controller to my 2023 400 with 1 100ah lithium battery. Based on other posts and manuals, the solar panel output should be connected to the +/- distribution block. The Victron MPPT 75 15 solar controller battery output goes to the distribution block. Can I connect the Renogy output to those wires or do I need to run separate wiring to the distribution block. I am putting the SAE connection in the Nautilus, so using existing wiring would be shorter.
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
0 ·
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
2025 Ford Ranger
