There is a lot of great information here about hooking up a second solar panel. Thank you!
I have a 2021 Tab 320 Boondock with factory installed solar and no external port for plugging in. I want to get a 100W (or maybe 200W) Renogy suitcase panel with a Voyager PWM controller. Before I read the posts here, I called Renogy and asked if I can just clip the new panel to my battery posts. He said no because the Voyager controller will shut down if another controller is charging the battery. Can someone explain why he said this (in very simple terms) when so many posts here said it works fine when you do that.
My second question: I want to get a cable to connect to my battery posts to make it easier to hook up the alligator clips. Is there such a thing? If not, is it easy to change the existing alligator clips that come with the Renogy to something I can use (SAE or M4C)? And related to this, I searched amazon for cables and all the O-rings seem too small for the battery posts: 8mm positive and 15mm negative. Is this standard size? I don't have access to my Tab nor a car battery.
This might be an important point: There is no way I can install a second Victron controller or install anything in the battery tub. Not only do I not have the skill, I'm trying to keep cost down as well.
Thank you so much for your patience with these newbie questions.
(decided not to butt heads with the hive mind
I have pretty much the same setup as you - 2021 320S Boondock w factory solar. I also have a 100w Renogy solar suitcase with Voyager PWM controller. The two complement each other very nicely, with no conflict. While at camp, we often have the trailer in the shade and use the solar suitcase to "chase" the sun. It works great. As I said, no issues if the sun hits the solar panels on the roof to get some charge out of them at the same time. And it's great to have the battery charged by the rooftop solar while you're going down the highway.
I installed an SAE port in the tub and have about 25' of cable so I can move the solar suitcase around. You can connect the end of the SAE port directly onto the battery terminals if you want. I ran all the wires to a bus bar just to make things cleaner, but straight to the battery posts also work.
Also, I have the Voyager controller as part of the solar suitcase, so there's no need to mount the controller in the tub. That makes the solar suitcase a standalone unit. I can use it anywhere, like to charge a trolling motor battery on my boat at the dock or to charge a battery in something else. I prefer that flexibility.
We changed to a 100aH Lithium battery but the setup would work just as well with the stock battery.
Good luck! I'd say forge ahead! It definitely is a more flexible arrangement than just having the factory solar on the roof.
2006 F-150
Coeur d'Alene, Idaho
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
My TAB came with a 75/10 MPPT Victron for the roof solar
In the spring I added another Victron MPPT but a 75/15 to drive my 200W Renogy suitcase.
This setup works very well for my 200Ah LiPO4 battery bank
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
So many questions, so little knowledge. Thank you for your patience.
Renogy 20' extension: https://amzn.to/46ImFaC
10AWG SAE to Male & Female Adapter 10AWG Cable with SAE Conector https://amzn.to/46NlkPV
Solar Crimper Tool Kit for Solar Panel Cable https://amzn.to/3XPCybn
