3 way norcold, 2018 320S almost perfectly level, shore power turned on, 20 amp breaker is not tripped, battery is new, and plenty of amps, 13.8 on the battery per the volt meter, after a few hours, no heat coming off the heat vent…certainly no cooling, yes frig set to coldest.
TIA
2024 Hyundai Santa Cruz and 2018 T@B 320S
1 ·
Does the Fridge display/control panel agree with an indicator light for your selected heat-source?
The vents are mainly used when cooling the fridge with gas.
In case of AC or DC power this could be the fuse/breaker has tripped or the heating element itself has failed. For propane mode the causes are a little more complex but the flame indicator will tell if gas mode works or not.
The most likely failure points will be:
1 - T-Stat (thermostat) unit or
2 - The AC Heaters itself
Easiest method for isolating the failure point is to remove the propane stove top and measure the AC Voltages.
Does the T-Stat Output { terminal 3 } have about the same voltage value as the input side { terminal 4 }
If answer is No, T-Stat is bad
If answer is Yes, Heater Element is bad or there is a wire connection issue between the T-Stat and Heater.
