HP 2440 Solar Controller
Jimid
Member Posts: 13
Hi!! Just want to confirm that this factory installed Solar controller will work with a AGM/sealed battery type? Thx!
Here is the manual link. https://forestriverinc.com/files/Component-Manuals/Electrical/Dehco%20(SRNE)%20-%20Solar%20Charge%20Controller%20Model%20HP2430,%202440,%202450,%202460,%20HP4830,%204840%20User%20Manual.pdf
Scroll down to # 10 to select battery type.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
That controller was the "stock" controller on the first factory solar panel builds in the 400. After a few months, it was superseded by one of the Victron units. If you just picked up a previously used 400 with the big AGM setup, it is most likely already configured for that battery type. Some info and discussion about it here:
There is a free Android app "Grape Solar" available on the Google Play Store that can be used to connect via Bluetooth to that HP2440 solar controller:
https://play.google.com/store/apps/details?id=com.ruijing.grapesolar2018 Tab 400 × 2013 Toyota Highlander Limited AWD0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
