Fresh Water Tank Drain not working
Have 2021 TAB 400 Boondocks--not able to drain fresh water tank with fresh water tank drain on exterior of trailer.
  • Use some fishing line to clear the valve.  There may be some debris clogging the opening.
  • I'll try that; thanks!
  • It worked--used weed eater cord to clean out the nozzle and now it's draining!  Thank you so very much.
  • Weed Wacker to the rescue!  Seriously, sometimes there are plastic bits left over from when they drilled the tank or sometimes there are contaminants that get in the tank.
  • Also watch out for mub dobbers if you have those where you live.  Every time I fill the fresh tank I feel for air flow coming out the of overflow and I quickly open the drain to make sure it drains.
    2021 T@b 400 BD  "Vixen Gail"
