Fresh Water Tank Drain not working
Toti
Member Posts: 3
Have 2021 TAB 400 Boondocks--not able to drain fresh water tank with fresh water tank drain on exterior of trailer.
Use some fishing line to clear the valve. There may be some debris clogging the opening.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I'll try that; thanks!0
It worked--used weed eater cord to clean out the nozzle and now it's draining! Thank you so very much.0
Weed Wacker to the rescue! Seriously, sometimes there are plastic bits left over from when they drilled the tank or sometimes there are contaminants that get in the tank.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Also watch out for mub dobbers if you have those where you live. Every time I fill the fresh tank I feel for air flow coming out the of overflow and I quickly open the drain to make sure it drains.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado1
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
