Fantastic Fan Stopped Working
I've checked the fuses (tubular in fan) as well as the 15 amp fuse in the box and both appear to be fine.  The fan has worked fine until now.  Everything else (lights, water pump, stereo, etc.) are all working fine.  The fan is completely unresponsive.  Any other ideas on how to troubleshoot what the problem might be?
2022 T@B 320 CS-S Boondock
2018 Nissan Frontier 4x4
SW Ohio
  • db_cooper
    db_cooper Member Posts: 749
    Maybe the switch that stops it when the cover is closed is stuck down?
  • Grumpy_G
    Grumpy_G Member Posts: 766
    Voltmeter or test light. Check both sides of the fuse in the power center and then check if power makes it to the fan fuse.
  • Buckster
    Buckster Member Posts: 62
    I just checked the switch and it is up and pushes up and down.  Perhaps I need to spray a little contact cleaner on it and work it up and down.
    SW Ohio
  • Buckster
    Mystery solved - I just noticed the thermostat dial had been turned up toward heat. I turned it all the way back to cold (blue) and presto, the fan started right up!  Thanks for the responses!
    SW Ohio
