Fantastic Fan Stopped Working
Buckster
Member Posts: 62
I've checked the fuses (tubular in fan) as well as the 15 amp fuse in the box and both appear to be fine. The fan has worked fine until now. Everything else (lights, water pump, stereo, etc.) are all working fine. The fan is completely unresponsive. Any other ideas on how to troubleshoot what the problem might be?
2022 T@B 320 CS-S Boondock
2018 Nissan Frontier 4x4
SW Ohio
SW Ohio
Maybe the switch that stops it when the cover is closed is stuck down?2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Voltmeter or test light. Check both sides of the fuse in the power center and then check if power makes it to the fan fuse.0
I just checked the switch and it is up and pushes up and down. Perhaps I need to spray a little contact cleaner on it and work it up and down.db_cooper said:Maybe the switch that stops it when the cover is closed is stuck down?2022 T@B 320 CS-S Boondock
SW Ohio0 -
Mystery solved - I just noticed the thermostat dial had been turned up toward heat. I turned it all the way back to cold (blue) and presto, the fan started right up! Thanks for the responses!2022 T@B 320 CS-S Boondock
SW Ohio2
