Cushion covers- great for dogs-economical
nettles
Member Posts: 30
I used 4 mini-crib/play yard fitted, quilted waterproof sheets (39" by 27" by 5") to cover the dinette and sofa bench cushions.
Then I used zippered king size pillow cases (20" by 36") for the back cushions on the side benches. A standard pillowcase will work on the odd shaped sofa side cushions.
I removed the glued Velcro strips from the bottom of dinette bench cushions. The Velcro caught on the sheets. Also, I was tired of the mess that the glue made on the cushion bottom. After spot testing, I used GooBGone on the vinyl cushion bottom. I rinsed frequently with water after applying in small sections with no problems. (I'm not sure if the Velcro was factory or done by previous owner).
I also used zippered king sized pillow cases on the insert cushion I made for the 5 1/2 board extension twin bed mod.
The play yard sheets were $26 for a package of 2. The king size pillowcases were $15 for package of 2. So total cost was under $100.
I'm very happy with the covers. The dog likes them too!
2018 T@B 320s, 2013 Toyota Highlander
Great idea! Only wash what the dogs muck up😂Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
