Has anyone swapped the WFCO8735 AD (for auto detect) converter for the Progressive Dynamics 4000 Series Mini RV Converter?? I put the WFCO 8740AD in my 2017 320S and have had nothing but aggravation. AD is supposed to stand for Auto Detect, meaning it is supposed to detect that I have a lithium battery and charge on that basis. Your have to jump through hoops to get it to switch to lithium mode (yes, I've seen the WFCO videos and gone through the process with WFCO support) and then it keeps reverting back to lead acid mode. It should be listed as MD (Might Detect), or RD, for Random Detect or Rarely Detect. The Progressive Dynamics unit has a switch to get to lithium mode. I have communicated with WFCO support and even pulled the unit out and sent it back for a firmware update (gone for nearly a month). It still won't stay in lithium mode. I just want something that works without a hassle.
2018 T@B 320S. 2017 Toyota Highlander AWD
1 ·
Across many forums, they seem to be quirky and unreliable. As an option, instead of changing out the entire unit again you could use a dedicated lithium battery charger (such as a Victron IP 22) for your battery(s). You could wire it through an off/on switch. Is your lithium inside or out?
Southern Maryland
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
It is not a WFCO Sales video - - - - Does have a WFCO Support Tech explaining.
Video take-away seems to be Yes - - it works but other factors like dual charging sources (solar), trailer cabin DCV loads, charge wire size (voltage drop) are causing huge RV Owner Confusion.
I again completely discharged my Powermax battery and have given the WFCO AD unit several days to detect the LiFePo power profile. The green diode is still shining bright, so mine's still in never-detect mode.
2023 T@B 320 S Boondock
WFCO converters have a history of rarely charging in bulk (14.4 - 14.6v) mode. They tend to stay in 13.6v absorption mode which significantly increases charge times due to reduced charge current. Only a seriously depleted battery or large inrush of discharge current can force some WFCO converters into bulk mode. Even then, it's typically fleeting and temporary.
Several RV's we've purchased in years past had WFCO converters. They all failed the bulk mode test and only produced 1/3 to 1/2 of their rated charge current. These days we typically install Victron or Xantrex inverter/chargers, but back-in-the-day we replaced the WFCO's with Charge Wizard equipped Progressive Dynamic converters. Their charging performance was superior to WFCO in everyway---always producing their rated charge current in bulk mode.
Before we started a number of electrical upgrades on our new '23 320 (back in Aug), we quickly tested the OEM 35a WFCO "auto-detect" converter to see how it would charge a new Group 24 lead-cell battery the dealer installed---more out of curiosity than anything else. As expected, the WFCO stayed in 13.6v absorption mode and could only output a measly 8a of charge current even though the battery was seriously discharged. Our 320's excessively long run of OEM 10 gauge wire that meandered from the tub battery, to the battery disconnect switch, then back across the trailer to the WFCO converter, compounded the problem with a ton of voltage drop.
Disappointing performance to say the least. It is what it is.
I don't know if you saw my OP re the 8735-AD-MBA I purchased on Amazon. Basically, I called WFCO to order the jumper and was told, the assembly I have is not theirs but a knockoff. Anyway, I'm looking to get the 1k ohm resistor to solder it into mine since WFCO won't send me a jumper. I see different sizes on the wattage as well as having to order 100 of them on Amazon! Do you know the correct wattage as well as where I might get just a few? TIA 😊
Believe the resistor is "used as pulldown" on a uP controller telling it a bit is set to zero. No current draw - - any wattage resistor will be fine.
