Clamshell Piston Failure on T@B CS-S 2021 - Looking for Repair Suggestions
MikeMurphy
Member Posts: 4
Hey all!
I have a 14-month-old T@B CSS and one of the clamshell pistons sheared off when it was closed a few days ago. (See photos below.) Root cause might have been the screws were overturned and the top bracket receives the most shear stress when the door is closed. Any ideas for how to repair it? I have the original piston, so I just need to know the best way to re-fasten the bracket. I'm sure there is some sort of wood filler required, but I don't know what kind to use. Or, perhaps, there is an after-market bracket available...?
I want to avoid taking it to the dealer for repair because I think they keep a long backlog, and if I can get the right information and parts I probably could do the rest just fine.
Also, after it has rained heavily water flows out of these holes when the lid is raised. I suspect water might be getting in at the top close to the hinge--and maybe related to the failure. Any ideas on this would be appreciated as well.
Thanks!
Mike
I suggest that you email tech@nucamprv.com and send pictures. They will advise the best repair.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Following up to close this out... successfully repaired thanks to advice from tech@nucamprv.com!
So, just caulk and move the bracket over?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The hinge is pretty well sealed. Water gets in around the edge of the frame. Once I figured that out and caulked the seam between the sheet aluminum and the frame, all the water coming through stopped.2018 320CS-S
"Just Enough"0 -
Yeah, I moved the bracket laterally instead of vertically as I figured that would be closest to the original range of motion. Difficult to caulk smoothly upside down LOL. I'll have to file down the rough edges for neatness soon.0
- 143 Events & News
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
