I want to add a 12v receptacle to run off the battery (not the inverter or converter) in the bed cubby on a 2023 400. Where should I tap into the battery circuit? Plan on using it to run a USB plug for cell phone/laptop charging, do not want to run the inverter. Could I run it off the Victron MPPT Controller Load terminals (not currently used)?
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
0 ·
From RVTravel:
If boondocking the inverter must be turned on to operate the 120v and the usb outlets. If on shore power it will operate without the inverter needing to be turned on. There is no longer a 12v cigarette style outlet in the cubby.
So @DaveC look closely at your outlet. If you only need a USB it should already be built into the 120v outlet. Here is a link to NuCamps walk through of the 2023 400. At about 5:40 in they show and go over the features of the bedroom cubby, which includes the combo 120v/usb outlet.
Virginia Beach, VA
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
https://a.co/d/6IQu19v
2020 Tacoma TRD Off-Road
