I've owned my tab400 for a bit more than 4 years now and I never had the hitch come off the ball until recently. Everything was hooked up as required and I was going into the storage yard which has a steep entry way which I hit at just the right speed and it found the right frequency. That was enough to disengage where it activated my e-brake and fell on the chains. Other than bending the chain car attachment and some minor scratches everything was ok. I was lucky there wasn't more damage and it wasn't too much work to get it back on. I was also fortunate that it happened with no traffic behind me.
Just a reinforcement to pass along that there is a very good reason for all the safety features when towing and nothing should be bypassed....even for short distances. It could have been much worse lets say I was going fast or on a hill. If you hit just the right frequency on some of these roads that may be just enough to have that happen. I hate to think of this happening on the highway when your e-brake actuates and by the time you figure out what's happening you're trailer is locked up. Makes it hard to get over to the shoulder. As an FYI the e-brake cable release is keyed so don't try to jam it thinking it needs special tools to re-engage. It can be done with hand force but you need to orient it right. A bit of a blind operation.
I've been towing trailers for a number of years and there have been many of these minor things that keep you from taking it completely for granted. I've been thankful that nothing has been severe but it could have been in at least 2 cases (non tab related). Learn all the recommendations from the experts and realize they are all there for good reason. Ie...Follow the guidelines for tow vehicle size, tongue weight, trailer weight distribution and positioning, use the right trailer tires, don't go too fast, etc.
2014 Jeep Cherokee trailhawk
2018 T@B 400 (white w/ red trim)
0 ·
I stick my fingers in there too. I do make sure nothing has a possibility of moving before I check the fork under the ball. And I agree completely. All those safety protocols are present for a reason.
"Just Enough"
I may never know what really happened but the main lesson here is always use all the backups just incase.
Also, looking at the top of the ball at the specified weight capacity of your Hitch Ball. There are several capacities of the balls and just because it is a 2 inch ball, it can have different capacities. I use a 7000 lb ball for our 400.
The tab that the latch connects to appears to have a stress crack or was bent somehow.
The tab that extends above the horseshoe was bent ever so slightly forward(1/16-3/32 as a guess) somehow and prevented the mechanism from positive locking. The pin could be inserted but the whole thing was loose and not as locking tight as it once was. It took so little of a bend to change the once solid latching. Seems like the steel is probably a very mild steel that stress cracked easily.
I don't recall any specific physical situation that would have damaged it.
The love taps you see on each side was what it took to get the hitch latch bent back into correct position to be able to use and get on the road but I am fairly certain its strength is compromised and needs replaced before next outing.
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r
The road out of the place was very uneven and put my rig through some contortions...but I don't think it ever bottomed out. After that, I started noticing a slight 'clunking' noise when I would apply the brakes. I assumed the gain setting on by brake controller needed tweaking...but nothing made a difference. I found a convenient place to stop and I checked my hitch. At first glance, everything seemed ok. But, after lifting and bouncing the tongue, it actually came uncoupled with the locking pin still in place.
I reseated everything and replaced the pin and it was fine the rest of the way home. However, I'm still confused about what happened.
When I got home, I removed the ball from my TV and clamped it into the hitch. It seems to be secure front-to-back and side-to-side. However, it would move up and down...about 1/8"...which doesn't seem right. My coupler has no adjustment mechanism that I can see and, to replace it, it seems you would have to grind off a large rivet pin.
Just thought I'd add to the discussion!
2023 Tab 320S
On my 2022 T@B 320S there is a large sticker stating that a 2" ball is required.
I do not see any up/down play on my setup.
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
