We have a 2022 T@B 400 and when we need to add water when dry camping, it seems the pump/siphon function on the Nautilus system is slow to add to the tank.  Will reversing the screen on the city connection to release the check valve help or will that damage the system?  Has anyone tried a water transfer pump to pull water from a jug and fill the tank at typical hose pressure?  Thanks for any advice and thoughts on this.
                0 ·
Have you Considered using a Jerry Can to Gravity Fill via the City Water inlet?
{ aren't typical electrical RV water pumps limited to 2+ to 4 gallons per minute }
As for the City Connection Check Valve - - - I don't see it as an issue
While doing a Gravity Fill allows maximum water flow rate (for plumbing hose size) if 'one' can lift a 5-gal (40'ish pound) Jerry can. . . . .
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
@DonF I don’t see why you could not use the power tank fill mode and use a transfer pump instead of a city water connection. As long as it’s under 50 psi when entering the system. But I don’t know anyone who’s done this. Just curious if your siphon mode is slower than it should be or if it’s normal and still just too slow for you?
If I could get 5 gallons into the tank using the sanitize mode in a few minutes I wouldn't have even asked the question. Tonight I filled a 5 gallon bucket and it took 10 minutes to pump maybe half in. I had the bucket raised and that may have helped some but my transfer rate is far slower than what I'm seeing in the posts. Reversing the screen on the city fill so the check valve was held open seemed to increase the fill rate but it doesn't reasonable to do that each time.
I saw a YouTube video where the lady was filling a 320 with what appeared to be a different Nautilus set up and the fill rate was good. Any further thoughts on what is "normal" or what else may be the issue will be appreciated.
Our T@B 400 appears to have a different Nautilus system than the 320s. It has one point of connection for potable water and that is what I am using.
A large diameter, short siphon hose helps a lot. I have a 1" hose about 2 feet long. I empties a 5 gallon bucket in 1-2 minutes
I added about 8 gallons of water to the tank and the pump was supplying water to the faucets no problem so I think the pump was primed. I used a 1" diameter hose to try and siphon water into the freshwater tank and it pulled water very slowly and there was a buzzing sound at the city water connection that may have been coming from the check valve. Last week I tried reversing the filter screen such that the check valve was depressed and the siphon rate was only a little faster. Any ideas?
Thanks for any thoughts/suggestions!
