Hello, I have a second hand 2021 Tab320s and I purchased it from an RV dealer, General RV, who will not answer any of my questions. I understand my warranty is void. I tried to find info online to no avail. My question is around the 2 systems. Do either of them need to have either city water, or fresh water tank full in order to operate? What do I need to do maintain either system? I read here about Alde Glycol replacement. Mine is yellow color and it seems low. I read that I need to flush it every 2 years which I assume wasn't done from new, so it is due now. I also read that I should replace it with new green colored Glycol, don't recall by which company. What about Air8 Elwell? Anything I need to know about it? I had a water leak so I run my Tab on dry camp for a while and used both systems. I camp a lot, sometimes for 3 months at a time. Are both of these safe to use for say 3 months in a row? I read all manuals. None of this is written in here, and there are no videos online that I could find. There are currently no dealers in Florida where I am to go and ask. Thanks in advance.
0 ·
Welcome to the Tab world.
The Alde needs to be filled either by city water or via your on board tank if you want hot water. But you can run the Alde with out having hot water (for sinks or shower) and it will heat the cabin just fine.
Re: Maintenance:
Air 8; Very minimal. There is a thin filter you can access from under the bunk on the inside. It's on the right side of the unit. It takes a bit to get the cover off. Finding a replacement seems harder than it should so most just clean it. Check every once in a while that the intake and exhaust vents under the trailer have no obstructions. There are screens over them and it should be fine...but always good to check every once in a while. The only other thing is some people change the setting so the fan stays on when the setpoint is reached and the compressor kicks off. I had it that way, but have noticed in very humid areas (south) the cabin area gets very humid just with the fan running. I switched it to have the fan cycle on/off with the compressor and the cabin stayed much less humid in between compressor cycles. But some people like the noise to be more constant than cycle on/off.
Alde; The only maintenace is to change the glycol every two years, independant if you have the older yellow or newer green/blue glycol. Some owners have changed to green from yellow, but others have stuck with the yellow. The reason Alde made the change is because corrosion has been an issue on some parts (mostly the small inlet/outlet pipes of the fin radiators) and Alde says the green glycol will prevent this corrosion. There are cases that owners who changed to the green glycol (from yellow) still have had corrosion. It is unclear if the corrosion began before the change or not. I am not aware of any corrosion found in any unit that was delivered with the green glycol, but it's only been out a few years. You can do a search on this forum and find tons of threads and very long discussions on this topic and make your own opinion. There is DIY method in the files how to change the glycol. It has been used succesfully by many. There is also a post on this forum with suggestions on the method that is helpful to read if you plan to DIY it. There is a wide range of costs for dealers to do it from $275 to almost $1000. I believe there is a Alde/Truma service place somewhere in Florda.
I've taken multiple 2 months trips and the Alde is on all the time with no issues. The most I've used the Air8 is for about a month when I visited the US SE. But I've read of others in Florida who have used it longer.
Keep asking questions...
Southern Maryland
You can find a Adle User manual here:
Adle User Manual in Resources Section of Forum
Look for this post - -
There also an Air8 Manual here (first post):
Alde - the preferred glycol is Rhomar (blue), the old one is by Century (yellow). Your glycol may be low. If you have no doubt that it is Century, you can buy some time by adding some Century. I believe you can also add some distilled water, but that will further dilute the concentration and freeze protection. Best to get it changed ASAP.
As far as using the appliances continuously, nuCamp does note in the manual that the TaB is not intended for full time use. In general, I think if you are only using the Alde for hot water, then turning it on only when you need it may prolong the life of the system.
You want the premixed 50% solution available at Amazon.
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
