2019 T@B 400
Walker Tent
2023 Chevy Silverado LTZ TV
Suggestions to Cover 2023 Tab 400 A/C Grate
We have the above-named trailer which was purchased a few months ago and which we plan to take to Alaska in summer, 2024. Our concern is with the positioning of the A/C grate on the side of the TT. Having RV'd in Alaska in the past, we know how much mud splashes up and covers the entire bottom half of any RV on certain roads in Canada and Alaska.
We are thinking of making a cover (perhaps plexiglass) which can be screwed on when the mud starts up and we no longer need to use the A/C. Has anyone done something like this? Any suggestions are appreciated.
I think your plexiglass solution is a solid approach. Its rigid, and fastened tight, should withstand travel. Consider the thickness when making a selection, i.e. too thin blows of, to thick may falloff. Just my initial thoughts. Safe travels.0
Thank you for your comments TwonuCampers. I'm thinking the plexiglass will look okay and be weather resistant. The challenge will be keeping water out (perhaps use rubber weather stripping) and of course securely attaching it (there are 14 screws holding the metal grate to the TT so maybe using some of these existing screws around the perimeter). Anyway, the project is still in the drawing board stage!0
I had access to some scrap 1/4 inch Lexan and made a cover with that. I took off the snaps and used the holes for sheet metal screws. I carefully drilled holes in the center, top and bottom for two more screws for a total of six. I then put on some window, weather stripping to seal it around the perimeter. Looks and works great.
Doug
2022 400 Boondock
2023 Tacoma TRD Sport
Western Maine1 -
Doug, thanks for the comments and especially the photo (it helps to confirm what I had been planning). By the way, nuCamp eliminated the fabric cover and the snaps on the metal frame on the 2023 400!1
Another option is to pickup some aluminum L-bracket and corrugated plastic display board from a big box store. Take off the clip screws if you have them and screw the L-bracket directly to the existing ledge on top front and bottom. It should leave a small gap. Slide in the plastic sheet making sure it has a friction fit and you are done. It keeps the water out even when you are towing. I painted the L-bracket white to match the AC frame.
AndreO
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat2 -
Check our the company Sea Biscuit in TN. They make custom covers for the t@b.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
