Looking for advice on using a Subaru Outback as a tow vehicle for a new Tab 320 S (not Boondock). The Outback has a towing capacity spec of 2700 lbs and tongue wt spec of 240 lbs. Subaru dealer advises it would be fine but just wondering if anyone has actual experience with an Outback or similar size suv.
0 ·
2023 Tab 320S
That said, a lot depends on how far, how often, and your level of experience.
Remember, the weight of everything that did not come with the trailer and car when new counts towards the rated capacity.
3500 pounds has long been the recommended minimum towing capacity for comfortable towing of a basic T@B 320.
Be careful.
Have fun!
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
Please also consider that if you are involved in an accident of any type the insurance companies will look very closely at your towing situation and will take every opportunity to hold you responsible if you are not within specifications.
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8
"Just Enough"
TV: 2022 Subaru Outback
Portland, OR
"Just Enough"
