I have an Ecoflow Delta 2 and a 220W Bifacial Solar Panel. I use this in places other than my T@B, but would like to use this as an alternate power source. The Delta 2 has several DC outputs at 12v and 10A -- standard cigarette lighter and the smaller DC-barrel connector.
If I wanted to feed this output into my existing system (2019 320s Boondock Edge with 100A Interstate lead-acid battery), what would be the best way to do so?
I am looking into an SAE port or an XT60 input. The panels themselves use MC4 connectors, but the only solar charge controller I have is in the Delta 2.
Looking for best practices and some "why's" to help me understand the "what."
TV is 2007 Kia Sorento EX with 3.8L engine
0 ·
The Interstate is 100AH?
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Of course, I can plug the tab into the AC outlet of the Delta, but trying to avoid the losses by staying DC to DC. And very glad I have a three-way fridge!
"Different types of lithium batteries and lead-acid batteries are not recommended for use together, because the load characteristics and capabilities of the battery are different, which will lead to abnormal conditions and safety issues."
I was not aware that DC was 2-way and that plugging into an existing port would work to charge. My plan is to put an XT60 port inside the T@B near the inverter and wire directly into the DC wiring there (with a fuse). I may later change out the battery switch to one that allows battery #1, #2, or both. The XT60 port allows me to use an existing cable that came with the Delta.
While I love the 7 pin idea, the Ecoflow is a very pricey extra battery, and I feel better keeping it inside the T@B.
I'll post some pics once done.
managed by VE Smart Network
I would like to run a new wire from the J-Box to under the bench seat but for the life of me can't get anything to fish through. I can't clearly see the "in-between" space to be able to properly fish -- it's going somewhere, but not coming out under the seat.
Here is what I am trying to do:
Install a new three-way battery switch in the front box.
- Battery 1 = Lead Acid that came from the tab.
- Battery 2 = The Ecoflow
The common output from the switch would go to the current red 10GA power wire through the J-Box and power the trailer as usual.My rationale:
- The switch keeps the battery chemistry separate. The trailer is powered by Battery 1 or 2 only. (The switch has a "both" setting which I would not use.)
- I want to leave the battery switch in the current location. I could move it inside, but the current location allows me to easily check I have set it to Battery 1 before towing, thus keeping the trailer brakes operational.
- I want the Ecoflow inside the trailer to prevent theft and keep it dry. That's the purpose the wire from under the seat -- to bring the 12v hot back out to the switch in the storage tub.
While I'd love to figure out how to fish through the current tubing, I am open to other ideas to get the wire from one end to the other and keep it sealed against dust and water.TV is 2007 Kia Sorento EX with 3.8L engine
And this one:
In this thread: https://tab-rv.vanillacommunity.com/discussion/4597/running-wires-into-t-b
Going to give it one more try!
This is in a 2020 320S ...
This has turned into an interesting project. Try as I might, I was not able to do the deed and so cannot tell the tale. But I did figure out an interesting alternative. (Actually, two alternatives.)
1. From the spare battery thread, I decided to make a 7-pin to cigarette lighter cable to allow me to power externally from the Ecoflow.
This was assembled from the following items:
- CURT 58150 Vehicle-Side 7-Pin RV Blade Trailer Wiring Harness Connector
(https://www.amazon.com/dp/B001EP0G72?psc=1&ref=ppx_yo2ov_dt_b_product_details)
- YCIND Heavy Duty 12AWG 30A Male to Male Cigarette Plug Cigarette Lighter Adapter Charger Cord With LED Lights 3ft (3FT)
(https://www.amazon.com/dp/B0B2F9S698?ref=ppx_yo2ov_dt_b_product_details&th=1)
- Scotch 130c black rubber splicing tape
(https://www.lowes.com/pd/Scotch-130C-Black-Rubber-Splicing-Tape-30-ft-Black-Electrical-Tape/5014312885)
The tape is probably overkill, but it keeps everything tight and waterproof.
2) I decided to create permanent conduit using 3/4" Schedule 40 liquid-tight conduit. It will go from the front storage tub, above the corrugated plastic along the trailer frame, and then into an LB conduit box up through the floor under the seat.
I've added an XT60 connector to plug in the Ecoflow. That will go back out to a four-way battery disconnect switch in the storage tub. Power to the trailer will come in from the J-Box using the original wiring.
Still in progress, so no more pictures. I like the idea of easily fishing this conduit for future projects like a backup camera wired to the reverse lights on the 7-pin.
We're headed to Gulf Shores, Alabama for a week, so no T@B projects until I get back.
