I was doing my regular post long-trip cleaning (4+ months) and maintenance a month ago, flushing everything out really well, sanitizing, etc.
In doing so I decided to see how much water I could put into the gray and black tanks, gallon by gallon to see when the ⅓, ⅔, and full lights came on.
I have a 2021 T@B 400 which the specs show the gray tank at 18 gallons and the black tank at 12 gallons.
The black tank worked as expected and went to "full" between 11 and 12 gallons and I poured 13 gallons in with no issues and then drained it.
But on my gray tank the full light came on before hitting 11 gallons and by the time I got to the 14th gallon (I kept going as the capacity stated 18) my kitchen sink was backing up. I had flushed the tanks several times before trying this and the light indicated "empty" when I started (and it was completely empty). This surprised me so I drained it and tried again. Same exact thing happened, full light came around 11 gallons and sink started backing up around 13 gallons.
My initial thought was maybe there was air getting trapped in it, but I don't think that would explain the full light coming on at around 11 gallons. Until the sink backed up at 13-14 gallons I though maybe it was just a very conservative placement of the "full" sensor. But I'm 5 gallons short of stated capacity. Trailer was perfectly level during the test.
Anyone else run into this? Or even tried measuring your actual capacity?
0 ·
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
2020 Tacoma TRD Off-Road
2022 400 Boondock
2023 Tacoma TRD Sport
Western Maine
Sold 2023 Tab 400
Sold 2018 T@B 320S
On my '18 320S I did verify the black tank gallons vs SeeLevel percentage full
(which was/is very accurate BTW) but never did the fresh or gray.
That said, an oddly shaped or misshapen tank could theoretically trap a couple gallons of air in a pocket where it couldn't escape out the vent. Seems unlikely, but who knows.?
Measuring the actual functional capacity of the gray and FW tanks has been on my project list for years. Maybe next year... :-/
Optimally, I believe it should be located on the other side of the trailer under the kitchen sink.
We aways like our head side of the bed to be higher vs lower but only .5 degrees, not three blocks.
