New Tab 400 Excitement and woes.
Glad to have this new Tab 400. Quality throughout is excellent compared to everything else I saw. Really stoked to use it.
First issue discovered on take home day. The front and rear window gaskets got stuck to the windows and ripped - I assume from sitting in the sun a long time and never being opened. No big deal, called dealer they ordered them. Taking it in for them to be replaced tomorrow. Awesome.
However we are now at several other issues. I tested the Alde heat and water - works great. However when I went to double check and test cold water today the bathroom sink has 0 cold water - nothing comes out at all not even air. Hot side works fine. Also of note, the water pump runs for a good 10-30 seconds after turning off the faucets. I do not see any leaking water. And finally, I have not filled any of the tanks past half. I moved the trailer twice (maybe 20 feet on my driveway to hookup the water) and water came sloshing out on the passenger side right  by the tire from under the black insulation piece . The dealer said the fresh  overflow is there which makes sense, however the tanks were NOT filled to the top and like I said I barely moved and the water came both times I moved the trailer on flat land 20 feet. Could it possibly be rainwater pooling right by the tire somehow?
Anyway, I’m going to tell the dealer all this tomorrow. My question is am I missing something obvious? This is my first travel trailer and I’d like to learn. Besides messing with all the features I haven’t done anything except fill the freshwater tank halfway, and try out the city water (with pressure regulator). All the external drains are closed. I peeked at the alde unit under the bed area and all looks well. Zero leaks that I can see. Is there a cold water valve somewhere that maybe they forgot to put on for the bathroom sink? Shower and kitchen work fine.  Just want to make sure I’m not being silly, as I feel like all 3 of these issues are somehow related.
The dealer has been great and I’m going to ask all of this, but there’s nothing like the hive mind to help you learn. Thanks everyone!
Regarding the tank levels, the indicator lights are not very accurate and may change with the levelness of the trailer.
Lastly, make sure when you run the pump that you are disconnected from city water. Not sure how the pump responds when a system is already pressurized.
appreciate everyone, and I’ve been reading this forum for weeks trying to learn and prepare.
edit- I’m sure most of this is just new user error. So please if I’m being dumb tell me
2020 Tacoma TRD Off-Road
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
