We need an inch or two to get our new 2021 TAB 320 Boondock into our 96"-high garage. We can let air out of the tires or maybe we could replace the big OEM Boondock wheels and tires (15-inch ST235/75R15) with regular Tab S 320 wheels and tires (205/75/14). Any reason that won't work or is a bad idea?
0 ·
@BOatguy just completed an axle swap, removing standard installing Boondock pitched, and he has kept the 14-inch wheels. Reference:
Overall T@B 320 height difference between the 14-inch and 15-inch wheels is around ~ 1.5 inches.
There is another owner/member that uses Rims without Tires to allow winter months storage in his garage. { just a thought }
Adventures: 51 Nights: 322 Towing Miles 41,200+
Odessa, Fl.
And mega congrats on a relatively easy solution to the garage issue. Deflating is way easier than changing wheels and tires.
2022 T@B 320-S Boondock Edition
2022 Outback Limited XT
SOK 100ah LiFeP04 Battery
