Thanks
qhumberd
Moderator
Blow Out Water with a hand pump?
I am new to winterizing. I keep my tab outdoors in California. antifreeze is not necessary. I want to drain all of the water from the trailer for four month winter non-use. 1) Do I need to drain the water heater tank as well as fresh water and gray water tanks? 2) I do not have an air compressor. After draining everything, can I use an adapter and blow out the remaining water with a hand pump?
Dan
2023 Tab 360 boondock
