Over the weekend my wife was sliding open the screen door open and the bottom of the screen door frame hit her foot while she was pulling it to open. As a result the
top string anchor popped out (see pic). Taking a quick look I don't see exactly where it was attached, does anyone have any info on this? I asked her and looked around to see if anything else "flew off" but could not find anything.
It would be nice if I could finagle this anchor back in place with some long needle nose pliers (if I knew where it is supossed to be mounted). Or do I need to remove screen door from framing? What are my chances that the door is shot?
I recall it was not easy to get it back in because of the tension and routing of the string, but it was doable. I was worried I was going to have to remove the screen but I did not. If you remove a corner I think you may see where it goes.
Kevin
My screen door also had a tensioner break where the set screw pierces the plastic tensioner. Made this tensioner from a piece of aluminum stock. Seems to work great. Rather than using crimp sleeves to attach the cord to the tensioner, I used a surgeons knot. If it works for large fish then it should work here. Also, I must note that the screen frame is very fragile in its construction and the assemble screws on the top section of the frame may need to be replaced with larger screws.
