Hello all,
I recently purchased a 2017 T@B 320S that has the Norcold N180.3 three-way refrigerator. On one of my trips, I recently lost one of the refrigerator exterior vent covers. These covers seem to be smaller than most based on the research I have done on Amazon, etc.. I have included measurements in the attached photos. I noticed another discussion similar to this one that another member posted. A link was provided to Norcold covers on Amazon. I checked the items at those links and they are not the same as mine (they are bigger). I reached out to my nearest T@B dealer and they said the Nucamp factory no longer carries the bases or covers. There are no part numbers on either the base or the cover. Does anyone know what the part numbers are or what aftermarket covers to buy?
Thanks!
Joel
Our resident experts, I'm sure, will have you pointed in the correct direction soon. And, welcome again!
I've also searched the forum and web for the 320S 14 x 7 inch side wall vents with no luck. Am suspecting that specific size is an OEM only part**.
If nüCamp has no old stock to sell. You maybe forced to cut a larger access hole for the retail available 20-inch wide panels or create some other DIY solution.
** Just like the factory standard fresh water tank fill port installed in the years before the
Nautilus System became standard. There seems to be generic brand part suppliers located
in the big RV Factory regions that produce lots of items that differ from Brand Name items
that are sold directly to builders at non-brand prices of course. RV Builder then stops
stocking said parts when no longer used in their rigs.
Plus, the original post is for a 'replacement' not a re-design
Don't believe the "computer fan" is standard on all model years. Might be for Fridge model 3136 around year 2015/16. While on the model year 2018, fridge 180.3, then is no fan. (I've added two 3-inch fans to my rig)
Fridge model 3136 rigs (some years) did use round vents.
Yet, again original post was how to replace the factory vent panel . . .
and web-search suggests a direct replacement is not available to retail buyers.
T/V Ford Ranger 2023 4x4
2015 Dodge Ram 5.7 Hemi
https://tab-rv.vanillacommunity.com/discussion/8261/permanent-screens-for-exterior-vents-mud-daubers-and-other-insects
These fit the 2017 T@B 320S with the Norcold 180.3 three way refrigerator.
First, the part number. It is Norcold 638406PW. In talking to the parts desk at the Nucamp factory, Nucamp no longer has these available and is not able to purchase them. However, they were able to provide me with the exact part number above.
I then went to Amazon and did a search for the part number and found them on Amazon. Here is one example of an Amazon seller : https://www.amazon.com/dp/B07M82QVXH?ref_=cm_sw_r_apin_dp_JFQA1Q7Z15252RTE30T5&language=en-US
They run about $35 +tax and it comes with both the base and the cover.
I ordered one set to make sure they were the exact ones, which they were. I ordered a second just to have a backup if needed in the future.
Hope that helps someone else out there!
And nice to know I was wrong (earlier comment) that these covers were OEM only/special.
We can order them - - even if the retail suppliers are limited in sources and stock - -
nuCamp is selling this door Direct From Their Web-Site
Does anyone on here have an extra they would be willing to sell?
https://www.ebay.com/itm/275858417136
Trips - 48 Mileage - 63,452
