Anyone with tips that are specific to winter camping in a 2020 Tab 320s, or just any general tips for camping in winter? I'm not necessarily looking for winterizing tips as there is a lot on this in other posts. I'm putting together a "winter camping checklist". Temps where I'll be camping likely will be below freezing (at least at night) but probably above 20. Not sure I'll be out there when it's any colder, at least not for this winter. TIA.
2020 Tab 320S BE "Moonbeam"
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
0 ·
2019 Toyota Tacoma
Asheville, NC
I've seen posts that indicate I can use the Alde heater after winterizing as log as I don't reintroduce water into the system anywhere. However, the T@B Owners Manual states in the first time use section of the Alde heater, "Confirm there is no RV antifreeze in the Alde® Domestic Water Tank".
Since the winterizing instructions, as I understand them, will put antifreeze throughout the water lines, this sounds like I won't be able to use the heater after winterization.
Am I missing something and I will be able to use the heater?
If not, I guess I'm still better off than tent camping :-)
Are you going to have an electrical hookup? Electrical power is probably the biggest concern. Solar isn't going to keep up unless you are only camping for a few days. A good thing is that the fridge doesn't have to run very much, but you typically use the lights a lot more due to the length of the day.
A nice rug is a must. The floor gets cold. Ventilation can also be an issue. Even in cold temps, keep the front window cracked and the fan cracked to keep some air flowing. If you don't you'll end up with a lot of condensation.
You will probably spend more time in the trailer. Take good books, card/board games, cribbage, or my favorite, a banjo. However, it does drive my wife crazy.
2017 F-150
Coeur d'Alene, Idaho
I don't have a banjo, but I am learning to play a dulcimer. However, I've been thinking about taking up harmonica since it would take less space and can be just as annoying...
My maiden trip will be Monday as soon as I pick up the T@B. The closest campground has only Class AAA sites and I plan on trying out every feature I can think of in order to check everything out. I also plan to winterize right before heading back home. I'm thinking for the rest of the winter, I'll plan trips around the milder days/nights, and leave the T@B winterized until next Spring.
2023 T@B 320 S Boondock
